bulldozer67
- December 19, 2009
Where to start - it's been a 8 week adventure and I still don't have a proper shifting transmission. I have a 2005 X with the 4.0 and the 5r55w. The original transmission burnt up (couldn't even move it). I bought a reman for $2k, pulled the old one out and put the new one it. It banged hard from 2nd to 3rd and the overdrive light drive came on flashing / trans overheat light came on the dash (with synthetic fluid). Sent that back and got another that shifted hard 1st to 2nd with no lights, but it smelled like burnt trans fluid whenever you drove it. It also had synthetic. Once again sent that one back and got another one (all these are rebuilt by Drive Power btw). Along with this new one I also purchased 3 new speed sensors and the range/neutrul saftey switch. It is running mercron V fluid. This one from park to reverse has a 5 second delay and engages hard when it does go in. However you can shift from drive to reverse and it does fine. On top of that all forward gears were normal for about the first 25 miles, but now I have a hard engage on 3rd to drive shift and the overdrive/check trans light lit up. I disconnected the battery for 5 minutes and now it engages hard on 2nd to 3rd and 3rd to drive and the transmission overheat light shows in addition to the others.
I don't know what to do at this point. Everytime the battery has been disconnected so it has had a change to reset. Any help would be appreciated. Thanks.
