Hurbold
- April 16, 2011
- Orlando, FL
- 2000 Explorer Sport OHV
New member, here. First, want to say "thanks" for everything I've found so far via search.
I just bought a 96 explorer A4WD for my mom, which I'm guessing has the B/W 4405 TC. I experienced no problems during the test drive. On the way home, however, it started a loud, fast "whirring-slipping" noise once the vehicle got into 3rd gear and I let me foot off the accelerator. It ended up getting worse once I got it home, in the sense that the loud grinding happened whenever I'd try to put it in reverse. Seems obvious that there may be a shift fork or some other issue in the TC.
As it happens, I'm splitting with my ol' lady and have to sell my 2001 f250 7.3, so I've got to get this fixed within a week or so, in order to have a drivable towing vehicle for my move. So, I figure this weekend is a good time to start.
I read up somewhat on how this system works, my only previous experience being with manual 4WD in Fords. I decided to so a little troubleshooting before I go any farther, and this is what I've found out.
1. The auto and 4-High positions produce the terrible "whirring-slipping" noise when trying to put the vehicle in reverse.
2. The 4-Lo position seems to function, with no "whirring-slipping" noise, though I've admittedly not tried driving it at high speeds while engaged. There is, however, a lower-pitched grind, kind of metal-on-metal sounding and feeling when going between reverse and drive.
So, I guess my question ultimately boils down to:
Which internal component of the TC, or other part if I'm wrong, might cause the vehicle to seemingly work somewhat properly in 4-Lo only?
I don't mind pulling the TC and doing the work myself; just trying to find the least costly and time-consuming way to handle this issue so I can gtfo of town.
My apologies if this was tl;dr or tmi or whatever
I did also search fairly extensively, which is the only source of the possibly erroneous component specifics I've discussed above. I also apologize if my specifics above have been covered in any thread(s) I've missed.
Thanks in advance for any answers/pointers and for your time in reading my post.
Bill
Bill
