DidiDavis
- July 18, 2010
- Davis, CA
- 1996 Explorer Eddie Bauer
Hi all,
I've had a 1996 Explorer Eddie Bauer V6 4wd for about 2 years. I've been having a vibration at highway speed since I bought it. It starts at around 60 mph and it gets worst as I go faster. When I release the gas pedal and the weight shifts to the front of the car, the vibration gets worst. The vibration is dependent on vehicle speed, not engine rpm. The vibration seems to be coming from the rear of the vehicle.
I replaced the shocks and axle damper, which were shot. It helped a little bit, but the vibration is still there. Got new tires, wheel balancing and alignment, it still vibrates. My next move will be replacing both U-joints of the rear driveshaft. They look ok, but at 9 bucks a piece it's worth the try. I got under the truck to check them out and noticed that I have a small play at the rear output shaft of the transfer case. The shaft moves a bit up (only up, not down), I'd say less than 1/8", and makes a clicking noise. The play is not on the U-joint, it seems to be either on the flange or output shaft, more likely the output shaft. Is that normal? Have you guys ever noticed if you have that play? I'll tighten up the nut holding the output flange onto the shaft, but it really looks like the play is on the shaft itself.
I've also checked the center axle disconnect in the front axle and it is working fine. Ball joints, steering rod, sway bar links and all other components are ok, therefore I'm ruling out the front axle and front driveshaft as the source of the vibration.
Any ideas?
Thanks
Any ideas?
Thanks
