kgb424
- September 22, 2008
- Minden Nevada
- 91 Mazada Navajo LX
I got A 91 navajo,I pulled the shifter motor out,put power across the yellow and orange wires the motor turned all the way to the stop,then switched the power it turned all the way to the other stop,put the motor back on pushed the 4 high button it shifted to 4 high I pulled the motor off, the transfer case was in the 4 high postion,but it will not shift into 4 low,took the motor apart the rubber piece on the spur gear was still there and in good shape, so its not the shifter motor, I turned the transfer case by hand, it will go into 4 high, it will go into 4 low, then back to 2 high no problems turning it by hand.the question is why won't it shift into 4 low,first I put it into 4 high, foot on the brake,tranny in neutral pushed the four low button nothing no light,nothing, when you push the button for 4 high it will buzz then you hear a click coming from the back panel on the drivers side,it does the same thing when you disengage 4 high but when you push the four low there nothing no light no buzz no click,I went by the ford dealer the service mechanic said thats not normal there is something wrong, they want to charge me $95 dollars to tell the problem, but screw that, the power mirrors and the dome light and the shift modual are on the same circuit, the guy I bought the navajo from said one day he was driving to work, and they got smoked,and they never worked again,I check every thing,I could not find any thing no melted wires or pinched wires,fuses are good,but they are dead, no dome light,no power mirrors and no 4 low could this be the reason it won't go into 4 low,please can some one tell what the hell is going on, and where to find a transfer case shifter kit, or some plans to make one cause, I guess that I will by pass the electronics and shift the transfer case by hand
