Transfer case swap | Ford Explorer Forums
Transfer case swap
RamonMtz
SAN LUIS
2001 Mercury Mountaineer
Found some info here that a bw4406 from f150 97-03 can be used for a swap into the explorer/mountaineer. I found a 04 f150 (same body style as 97-03) with the same bw4406 manual transfer case. Can i use it? Or does it need to be 97-03? Thanks in advance.
if its a 4406 then yes but depending on the year of your explorer / mountaineer you may need the earlier version with the speedo in the case , i think 98 and up used the abs sensor on the rear in which case the newer 4406 would be fine
My mountaineer is 2001. I'll go ahead and buy it then ill post an update. I will get the front driveshaft from the same truck
What engine is in the donor truck?
Only the driveshaft from a 4.6 equipped truck will work.
Is the shift linkage still there?
If so, grab it.
MT
If so, grab it.
MT
Isin't their a rule that the front and rear driveshaft have to be from different engines in different trucks ? I have herd of some people using expedition shafts and F150 transfer case.I really need a dam list.
4.6 front shaft and 5.4 rear shaft
Look in mountaineer greens heading under tcase swap.
MT
Following
Did the swap years ago. 2000 explorer,
4.6 f150 front shaft
5.4 navigator rear
Following
5.4 navigator rear
How was the power increase in 2wd mode from Full time awd ?
I Didn't notice any, the front axle is live so all the same parts are moving because of the wheels so it's still causing resistance.
