gijoecam said:
so what are you supposed to do if you have a flat tire? NOT put the spare on???
-Joe
You have a full size for a reason. For Short distances I would expect no problems but I would leave it on.
What this may explain is why viscous clutches TC wear out any where from 50k to 100k while non-viscous TC last longer(Jeeps, nv242, nv249). I read about a lot of Jeeps and some have a problem with early wear viscous clutch. With a Jeep you get a full size if you get a QuadrTrac (Viscous) They even had a recall few years back for Jeeps w/Viscous and a small donut spare, replaced with a full size.
It depends on miles, tires and air pressure, size difference of the tires and state of the viscous prior to the replacement of tires. One way would be never to rotate the tires for 30k. Here is an exaggeration for a rough idea. By never rotating the tires at all you wear front tires down to lower than -.5" than the rear, then add new front tires for a +.5 diff thus you actually have over an 1.0" difference for 20-30K miles. Thus for every mile a tire rotates 245-65-17 @ 706 times a mile and times 20k miles and you have over 14,120,000 rotations. This may be just enough. If you rotate and keep the differences <.05" then the viscous may not be used in this case and may last longer, how much?? I don't know, but I'll keep you posted as I usually keep my trucks for 10yrs and well over 100k.
In essence in the majority of cases it shouldn't matter, however a little bit goes a long way to helping or hurting.
For me after this discussion I rotated my tires last weekend and checked all the tire pressure. I will not allow any pressure difference what so ever (< 1lb diff), and now plan rotating the tires every Oil change. My 11yr Jeep XJ 150K (sold), My 9yr Jeep ZJ now at 105k both have had the nv242 TC, both needed rebuilds at about 100k.
Good discussion I have learned a lot about my new X. Thanks all.
Jim.
