transmision lines attached to radiator leaking | Ford Explorer Forums
dmr1203
Atlanta
1996 eddie bauer
Hey guys, I replaced the radiator in my EB and everything went fine, but I have a small dripping leak in the top transmission to radiator line. I have tightened it quite a bit, but there is stil a drip. Any ideas?
The leak is at the connection from the bolt to the radiator.
teflon tape it up.
slag said:
teflon tape it up.
Either that or use RTV sealant on the threads. Either should do the trick.
Is permatex the same thing?
yep it is
