Transmission at my wits end. | Ford Explorer Forums
nathansmith50
grand rapids, MI
2014 PIU
Had a delayed shift from second to third. but otherwise functioning normally.
except for the occasional flashing OD/Off light and then no shifting below third.
Then one day i lost drive and reverse...not completely but would only idle. applying accelerator had no noticeable effect.
then they suddenly came back and i had drive and reverse as normal for about 2 days.
then they went out again.
I checked the servo with "AB" on the cover and it's fine. I checked the adjustment of the linkage. it's fine. I didn't check the adjustment of the cable.
the code it gives me is shift solenoid B failure.
