Transmission cooler line problem | Ford Explorer Forums - Serious Explorations
hvanorden
Loveland, CO
2005 Explorer XLT 4.0L
So I'm putting a new transmission in my 05 explorer. I've got itit pretty much installed and when I went to connect the cooler lines I realized that the new tranny have bigger fittings than the tranny I removed. The female fittings on the new tranny are larger than the male fittings on the lines.
Do they make an adapter for this? Or what do you all suggest? The transmission is a reman unit from Autozone (I know a guy so I got a heavy discount)
I'd verify what trans you picked up. Do you still have the old one? Need to contact the trans rebuilder as they'll know the issue. Wrong year or wrong app. could just be a mistake when rebuilt.
If you've already solved this, let us know what you found.
