1996BLKBauer
- June 24, 2011
- McHenry, IL
- 1996 Eddie Bauer AWD V8
So I am about to wrap up just about every problem my Explorer had when I bought it, I have 2 things left, well 3 really, if you can consider the power antenna being broken a problem, the two real ones are the Pinion Seal... Still scared about that. And two the 4R70W transmission. Now in a couple weeks I will be doing a pan drop, and replace the filter, I will be going with the Motorcraft one for a replacement. But on RockAuto it says "Gasket Not Included", So I looked up the gasket, and will being going with the Fel-Pro Gasket... I want to make sure I will have Everything for this, because I want to have it all done in one day, without waiting for parts.
Filter:https://www.rockauto.com/catalog/moreinfo.php?pk=383562&cc=1119664
Gasket:https://www.rockauto.com/catalog/moreinfo.php?pk=128368&cc=1119664
I also would like to add an in line filter, There is one on RockAuto, I wanted to know if anybody is using it, and how happy they are with it, It is made my ATP... I would also like to know where everybody had hooked theirs up at?
InLine Filter: https://www.rockauto.com/catalog/moreinfo.php?pk=64527&cc=1119664
I greatly appreciate everybody's input on all this, I know transmissions are scary to most, I am sort of scared, but I know the filter needs to be changed out, because I doubt it ever has been done before.
