95ExploderOwner
- August 12, 2011
- Nashville, TN
- 1995 Ford Explorer XLT
Is there a way to pull the transmission fault codes without a scanner? I am able to pull the OBD check engine codes by jumpering pins on the connector, the check engine light will then flash the codes. Does anyone know if there is a way to obtain the transmission codes in a similar fashion?
