- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
A4LD transmissions...
LAURI, may I comment? How much do you need the truck until you sell it?
If you do not need to use it for many more thousands of miles, then sell it as it is. I have a 1991 XLT 4x4 for sale also, and the value is low enough that the expense could be more trouble than just selling it.
If you need it for quite a while more, than you need to be very careful with how you operate it until you know that it is fixed. These transmissions are decendants of a Thunderbird four cylinder application. Most transmission shops hate them because they often times burn up hundreds of dollars of hard parts. Some shops won't touch them because of the higher risk of expensive future failures.
If they wear out and are rebuilt before they burn up parts which don't usually have to be replaced, than they can last another lifetime. But if more damage is allowed to occur, they might fail repeatedly, and at double the normal cost.
I am a Rural Carrier, and my mail vehicle is a 1993 Explorer Limited 4x4. I hope to upgrade to a later model chassis with a five speed transmission.
I have a coworker who used an Explorer also with the A4LD. His transmission failed and he paid close to $1500 to have it rebuilt. It failed again a short time later, and the transmission shop rebuilt it again. It failed again not long after that, and he took it elsewhere, and paid $1800 to fix it again.
He quit delivering mail with it soon afterwards, and sold it.
Several people have given you good advice. Please don't try to force it to function(be gentle) until you have found and fixed the problem. The potential expense of replacing hundreds of dollars of hard parts should be your greatest fear. Once a transmission burns up(damaged non normal wear parts(hard parts)), they are much more likely to burn up again.
SOLUTION: Have the computer code checked in the hopes of pointing you to a problem that you can fix. Go to a transmission parts store, and buy a manual for the transmission. It should be less than $15. Also buy a kit made by TransGo, which I used in both of my Explorers. Ask at the parts store, it was called something like "A4LD JR." This kit is for preventative mainenance.
Read the manual and pull the valve body carefully, noting the different size of bolts, and the attaching parts. Install the kit, and any solenoids that need help. Look VERY carefully for any debris, including sediment, no matter how small. Any debris suggests that there could be debris anywhere else, including passages which could cause failures if restricted. Last, always drain the torque converter when changing fluid. This is about all that can be done without removing the transmission.
As a last suggestion for a preventative measure, ask a transmission parts or repair shop for a longer pin for the modulator valve. There is a pin behind the valve on the side of the transmission which affects the 1-2 shift. Pull the vacuum line from the valve, then remove the valve, then the pin. A pin longer by about 1/8" will firm up the 1-2 shift slightly. The pin that I used was given to me by a shop, for some kind of older chrysler transmission. It was simply a very common part that was longer, and I cut it 1/8" longer than the stock pin. My 1991 Explorer was slipping slightly going into 2nd, and these parts helped it greatly.
I know this is long, but I hope this will help anyone with this barely adequate transmission. If your's is not terminal, these ideas may help. Once they start to slip, or quit, don't drive them. Additional driving will add hundreds of dollars to the repairs($500+).
Again, good luck,
CDW
Again, good luck,
CDW
