Transmission help? | Ford Explorer Forums
Transmission help?
Elgato88
Benson Az
2001 sport trac
hey guys new to the group I just got a 01 sport trac with a bad transmission and I'm trying to identify what transmission it has in case I go down the road of purchasing one any help will be greatly appreciated
Pull the pain, drain and check the fluiid
If it appears good with no burnt smell or metal contamination, rebuild or replace the valve body.
Install new "O" rings on the reverse servo and install a new separator plate with bonded gaskets.
Search on the forum for 5R55E rebuild to learn more
Quick question I have a 2002 198k on it and already got a filter and fluid to do a filter change it still shifts good should I go ahead and do the filter change?
Yes
My opinion in 198K is that I would get a miti vac and quarts of tranny fluid and look at it. If its burnt smelling and dark, I would replace a couple of quarts with each oil change till the fluid looks better, then do the pan and filter. Old tranny's with old fluid do not like to be shocked.
Your transmission type will be the 5R55E.
You ever find out the answer was wondering the same thing
