Darkmand26
- July 22, 2021
- Okc
- 2016 explorer limited 2.3
Here's a strange one for you . I had the Customer Satisfaction Program "20N07" done to my truck Sept 2021. Comes with two year warranty according to service advisor. 2 days ago the transmission bolt that mounts to motor broke in half. Which in turn damaged all motor mounts, which dropped the engine. It damaged the belts, ac compressor, all the motor mounts, that they can see so far, giving a $2600 quote to fix just that. According to the dealer that did the transmission "recall", they wont cover it, unless it was a one time use bolt, which they say it wasn't. So the dealer where it is at now is awaiting my response. I dont know what to do, because in my mind if you tore down transmission and removed said bolt, reinstalled said bolt and said bolt was where the failure originated, it should be covered. Maybe the bolt was cross threaded I don't know, But also they installed it 1 year ago, so why did it fail now and not then? If anyone can lend some insight or some steps to takei would appreciate it greatly. i also have video of them doing the diagnosis if that helps.
