creeter
- April 1, 2009
- Cincinnati, OH
- '97 Sport
I have a '97 Sport with a problem. Long story short, it was accidentally put into 4wd low, and driven at highway speeds for a day. I noticed several problems immediately (chunking noises, the feeling of skipping gears), and we parked it, checked fluid color & level, and right a light check on things in general (the other half worked at Firestone at the time). Everything seemed fine. The next morning, it would 'disengage' after about 25mph, once fully warm. I pulled over and got towed home, and as it was coming off the flatbed (being driven and doing fine at low speeds), the tow truck driver asked if it was in 4wd, cuz it sounded like it was stuck. I looked and sure enough, it was. I put it back in park, disengaged, put it in reverse, and backed it into my driveway.
It sat for a few weeks, then I called around to some local tranny shops. One shop was very reassuring on the phone, saying it might be something inexpensive to fix, that they would look at it for free. So they came to my house, picked up the truck - by driving it & telling us it would be fine to do so, and took it to their shop. After 3 days, they still had not called. When I finally got someone on the phone who could talk to me about my truck, they told me the tranmission and labor would be $4-5000, and that's if nothing was wrong with the transfer case. This number seemed absolutely ridiculous to me.
I kept calling around and again, found another shop that sounded like they would be honest with me, and I had the truck towed from one shop to the other.
The guy at the 2nd shop informed me that the first shop hadn't opened anything up and that they probably destroyed everything by driving it in. I would need a transmission and a transfer case to solve the problem now. He quoted between $2-4000, depending on any 'difficulties' they might run into. Oh, yeah, and he said that since the truck was there over the Thanksgiving weekend (when they weren't open), I owed him $123 for storage of the vehicle, since they weren't fixing it right now & he'd had it for 5 days. Before he'd release the vehicle to me that day, of course. And he confirmed, they didn't do any hard diagnostics, either - based their assessment on what they knew about it.
Something tells me that neither of these cats were being straight with me. I paid the money to get my truck back, drove it home (less than a mile) at low speeds and parked it. Stored it over the winter, starting it every once in a while, letting it run in park.
I moved a few months back, and had to drive the truck the distance. It did great, shifting as I increased speed, but toward the end of the drive (between 12-13 miles) you could start to smell a problem. It's been parked winter-storage-mode since.
Then I'm watching a car show on Spike, and the guy on there is talking about being able to tell if you had a transfer case problem, or a transmission problem. He said if the problem is the transmission, then the truck won't engage into a gear, it's a transmission problem, but if you can hear the vehicle changing gears as you increase speed, it's a transfer case problem.
My first question is, does that theory hold water? Because it leads me to believe that my problem is in my transfer case...
My second question is, can someone please lend me an honest opinion about where to look next. I'm really not in a place to just lay down 5k to some jerk trying to take advantage, I'm sure most folks are in the same shoes.
Thanks in advance for your advice or suggestions.
