transmission problem! after filter and fuild change! help! | Ford Explorer Forums
puyunet
yojuda,puerto rico
96 xtl
hi everyone im new here and let me tell u this forum is awsome!.
o.k. let get to my problem i got a 1996 xtl ford explorer with a 114,### millage on it. i made some tune up my self . i change my transsmision fluid and filter. the thing is that everytime when the car is cold ,i star my car and when i put in drive it stay like in neutral or when y try to go over a hill slow it put his self on neutral. what up? i don't understand i use mecron v,put 4qrt on it and says it full. can some one help me???:eek: :roll:
other thing i forgot:
i use mobil 1 synthetic mecron v
engien is v6 4.oL ,96
...no, your filter comes with o rings to go on it's two inlets...
when i change the filter neither the old filter had it and the new one had it and i ask if there something else i need for chaging the filter in the ford store and they said no u have everything. so never found a old one.
..the o rings come in the box with the filter...usually in a plastic bag just the size of the o rings...
Those o rings are essential in order to maintain the proper prime. The filter acts as a sump inlet to draw fluid out of the pan, and recirculate into the transmission. You are most likely losing the prime every time your vehicle moves, and stops.
When you filled with fluid, did you follow the procedure outlined in the owners manual for checking the fluid?
You need to put it in all gears on a flat, level surface, then check the fluid level while in neutral with the engine running.
yeah i did that.
thanks guys! i put the o ring today and it seems fine. i will tell u in a week if is still working! thanks all:D
...you might want to keep an eye on this thread puyunet...since you were sucking air, someone might have some other info for you...good luck..;)
Hi, I am brand new here. This is my first posting so I don't know if I am in the right spot but here goes.
My 97 Ford Ranger won't shift into low 4x4. I am told it is the GEM. Interestingly enough the "Door ajar" light is on which I think is related to the problem.
So, I am shopping for a new GEM. I don't have remote locks.(I'm told that that is relavent.)
Regards,
Eric
Gem
Thanks for the suggestion Brooklyn but the shift motor is working well.
Can I use a gem from a keyless entry Ranger on a Ranger without keyless entry without reprogramming the GEM?
Does keyless entry mean a truck with a code on the door or a remote unlock?
Please pardon my ignorance.
Thanks,
Eric
Gems
Thanks Brooklyn, you are very knowledgeable!
My "door ajar" light is on all the time. Is that related to why my GEM won't allow me to shift into 4x4 low? I just got this truck so I don't know if it will normally shift into low if the door is open.
Thanks,
Eric
I doubt that it has anything to do with it. My van has 2 round disks on the side frame which meet another 2 disks on the sliding door. If the door is open, the 2 disks on the door won't close the connection, and it will show a door ajar light. All models of my van have an issue with the internal connection inside of the door which requires a new wire to be installed with crimp connectors. It was never officially a recall, but it should have been. I don't know if the Explorers have this set up, but I think they have another similar set up like my van for the rear hatch. The hatch has a built in switch which could throw a door ajar light. I had to replace it on my 88, but it seems OK for the other models. Maybe your issue is in the hatch or with one of the doors? Check a wiring schematic of the door ajar circuit for the color codes, and locations where the wires run.
