Tylers02
- November 24, 2008
- Overland Park, KS
- 2002 Limited
I purchased an 04 Limited V8 with 105xxx miles on it about a month ago. Test drove it probably 20 miles with no issues what so ever. Within maybe two weeks the problems started arising. First off I get a low speed shudder/vibration almost like the tires are rubbing. I'm guessing it's my limited slip clutch packs.
The main issue though, a few days ago after pulling off the freeway the tranny started shifting funny. Reved up before going into gear and the od light started flashing. On the same day the car stalled out at a stop light and abs light came on. All issues haven't happened again except erratic shifting after transfer warms up and banging into gear when putting it in reverse. The only code I pulled was p0745 solenoid a malfunction.
I purchased the Explorer for cheap but now I'm debating to just trade it in or fix it. I've done my research and have been on this forum for awhile as I use to own a 02 limited. Any help or advice is appreciated. I know the solenoid pack may fix the issue but is there any test to make sure that's really the issue?
