transmission slipping | Ford Explorer Forums
daniel6409
Frisco Texas
2000 xls
Hi
2000 lxs with 115,000 miles started to slip when it worms up. Shifts like new in the morning but going home it will rev up when shifts or does not down shift.
Help Thanks Dan:roll:
Welcome to this forum! It might related to the valve body gaskets, loose valve body bolts, improperly adjusted bands, dirts fluid, clogged filter, failing EPC solenoid, or a combination of things. More information would be required to make an accurate diagnosis. What's the repair history, maintenance, type of fluid used, and intervals between fluid changes?
Hi this is a use explore that I far as I know has not had any maintenace done. Shifting manualy it works ok. The overdrive light flashes when I use it. If I'm gentle when I pull away from stop it shifts ok. After long drives it will not down shift.
Thanks Dan
Thanks I tryed to check this but no reading, Do I need to press the o.d. butten befor taking the reading or should it show with the normal check.
Dan
