98FordLove
- January 27, 2021
- Calgary
- 96 Explorer XLT 4.0L OHV
So I just noticed this weekend that my auto trans is starting to slip when going from 1st gear to 2nd gear. It only happens when the trans is fully hot and been running for awhile. It doesn't slip all the time, just on occasion and it's very random. I do notice it tends to slip more if I am light on the acceleration. But if I'm noticeably heavier on the gas, it won't slip. This makes no sense, I would have thought that harder acceleration would cause the slip to show more.
I checked the ATF and it's dark red and smelt like hot rubber. I guess you could say it was a strong smell but not nessecarily a burnt smell. The ATF level was quite a bit over the max line, I'd say by half a quart. But I've been driving it with this ATF level for the last 3 years when the ATF was last changed and no issues until now.
1) Should I change the ATF and see if it helps?
2) It says on the dipstick to use Mercron. I'm 99% certain the ATF in my trans now is not Mercron. It's just standard Prestone's Universal American car ATF that comes in a yellow bottle.
3) Is there an issue of me keeping the trans in 2nd gear and then manually shift into D as I accelrate? Then shift back to 2nd gear when stopped. Or will this damage the trans? This way I can avoid the 1st-2nd shift.
What would be the next step?
Thanks
Thanks
