Lets start with some basics. Did you check the fluid level? Do you have manual 1st gear? Did you try to drop the pan, and check the low/reverse servo piston for a chipped shaft or bad O rings? Did this suddenly happen? Do you have a 2WD or a 4WD? When was the last time the fluid, and filter were replaced?
