Trany problem 99 explorer vin x | Ford Explorer Forums
rede2go
Bothell Washington
1999 plain jane
Hello all.
I have searched the forum and did not see my problem but im sure it will be pointed out that i did.
THe problem is as follows.
I have lost reverse, and at the same time 3rd and fourth!
I can manually start in low/first and then pop in in to 2nd. If i leave it in
auto mode when it should go into third it just revs and nothing.
So i am stuck with a car that can go 45 around town at 3000rpm in 2nd
and have to think about where i park due to no reverse.
HELP! fluid level is fine. Any thoughts on where to start as the option
of taking it to the shop is out of the question. the choice of food for the family or taking the car to the shop, well the family must and does come first!
I am open to ideas, Thanks for reading.
Ron
welcome ron
Welcome to this forum! It might have a blown valve body gasket. You could rebuild the valve body while it's already out of the vehicle. Check the sticky thread in the transmission section called the 5R55E valve body rebuild diary for more information.
