- May 13, 2000
- Cape Girardeau, MO
- 94 Sport 4x4
What's the best way to remove pesky caliper slide pins that won't come out?
I tried needlenose pliers, and so on and I couldn't do it. I don't have a lot of experience with brakes. Is there a trick, or special tool that helps?
Also, the rubber sandwiched between the slide rail pieces was deteriorated. Do slide pins need to be replaced? All I wanted to do was lube them, but if they need replacing I will get new ones.
