mr_roboteye
- November 18, 2008
- New Westminster / Vancouver, BC, Canada
- 92' Ranger 4x4 RC SB
Truck is 92' Ranger reg. cab, SB, 2.9L V6, 5 speed, manual t-case, manual everything, windows, doors etc, no a/c.
I have recently (2 months) replaced my cap, rotor, and put some nice big wires with 4 electrode plugs to pass emission testing. (it passed)
I'll try not to make this a frikken' novel.
Symtoms:
After cranking, can smell gas in engine bay, but no noticable leaks are present.
Truck will bump start and run fine, as if nothing's wrong. (No black smoke / overfuelling)
Intermittently, starting motor will crank noticably slower in some instances, then crank at normal speed.
Have tried cranking with throttle closed and wide open. Will eventually start with wide open throttle (after a very long, long time, cranking for about five seconds per time, then allowing about 30 sec. to rest), but if you shut it down, will not start again immediately after.
Thanks for looking, if any of you have had similar problems and could tell me what to investigate first, that would be great. I'm quite mechanically inclined, just need some experienced help.
later,
Dave R.
Symtoms:
later,
Dave R.
