scoarch
- August 13, 2008
- Vernon.b.c.
- 93 Ex
Hi all.
i have a 93 exp with the 4.0 engine.
when i go to start it in the morning it will crank over and fire right up but then the starter keeps cranking. i shut off the key and it still cranks over. move the key to the run position and engine fires up but starter is still turning over. this will happen 2 or 3 times and then will quit , usually after burping the throttle a bit. once the truck has been ran it is good for the whole day. seems to only be in the morning that i have this problem.
any advice would be much appreciated. thanks to all
