- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
I's not just the A/F ratio, loss of power from too big a pipe happened before computer controlled engines.
Sorry, wrong again, you are talking about very common knowledge from back then, when the A/F ratio was upset by increasing airflow, making the engine lean. It's the same thing.
It's the identical situation, except one is fuel controlled by a computer, and the older engine by a carburetor. A carb is not perfect in the same way the PCM is not, they cannot control the A/F ratio perfectly based on any random airflow. They are both "tuned" for a specific airflow they are intended to experience. When the airflow is increased enough, the result is a too lean mixture, which is "felt" as less power.
Go find any top mechanics that know carbs. Ask them what happens to the A/F ratio when you install a much larger header than the stock manifold. They will all tell you that the carb must be rejetted with bigger jets(to fix the lean condition). The same thing happens with a much bigger exhaust on a car with a carb. The airflow increases enough to make it run too lean, and the answer is more fuel.
Every airflow change you make, alters the A/F ratio from insignificant, to an amount you can feel. Fix the A/F ratio, and the result will be more power, matching the greater airflow. Regards,
