KPPCExplorer
- August 16, 2010
- Kings Park, New York
- 2002 XLT V6
I just got my Truxxx lift kit in and went to install it on my 2002 Explorer. I read that even though it was for the 2006+, it would work in the 2002-2005 Explorer with no modifications in the front and a little drilling in the rear. The kit requires that when you put the spacer on, you re-install the strut facing backwards, due to the fact that the upper bolts get relocated 180 degrees. On the bottom of my strut, there is a "tab"(for lack of better term) that points towards the rear of the truck. When I put the spacer on and rotate it, the tab points towards the front. Because it is facing the new direction, it sticks out too far in the front, thus not being able to go back far enough to mount in the lower control arm. Am I doing something wrong? Hopefully somebody who installed this kit before can chime in and tell me why the lower strut isn't fitting in the lower control arm. Thanks.
