Tsb* shudder in 2nd and 3rd gear | Ford Explorer Forums
Noslo351
Hebron Ct
2002 Explorer Limited V8
My 2002 Explorer V8 has this issue. I thought it was the trans going south. Thought I would share, I did not find this anywhere on the forum.
TSB
05-21-4 SHUDDER IN 2ND AND 3RD GEAR ON ACCELERATION - 4X4 VEHICLES WITHOUT ADVANCETRAC
Publication Date: October 5, 2005
FORD: 2002-2003 Explorer
ISSUE:
Some 2002-2003 Explorer 4X4 vehicles without AdvanceTrac (Interactive Vehicle Dynamics - IVD) equipped with an automatic transmission may exhibit a shudder in 2nd and 3rd gear on acceleration. This condition may be more pronounced when the vehicle is under load.
ACTION:
Replace the 4X4 control module following the procedure in Workshop Manual Section 308-07A. Refer to the Part Application Table for the correct part number to install.
Build Date (Off Build Plate) Build Plant 11th VIN Digit Part Number
Built prior to 3/4/2002 Louisville U 1L2Z-7E453-A
Built on or after 3/4/2002 Louisville U 2C5Z-7E453-A
Built prior to 3/11/2002 St. Louis Z 1L2Z-7E453-A
Built on or after 3/11/2002 St. Louis Z 2C5Z-7E453-A
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
FORD: 2002-2005 Explorer
MERCURY: 2002-2005 Mountaineer
does this also go for 4.0 engines?
TSB
ISSUE:
ACTION:
WARRANTY STATUS:
Yes, the Tsb isn't engine specific. Also, I was able to find the motorctaft replacement at Rockauto.com. Just do a part number search.
