turbo | Ford Explorer Forums
turbo
pat3
vancouver washington now i reside in hawaii
91 xlt 4 door 13inch lift
hay guys i have remote mounted my turbo by the out put shaft on the transfer case ill be posting pics soon
I used a flowmaster y pipe to bring the down tubs togeather and feed into the turbo. Installed pacesetter headers (speeking of those any one got feed back on them?) The turbo oil return line runs to a tilton pump, then to a b&m street rod trans cooler, frome there dumps into the pasenger valve cover. Controlling fuel preasher is a sards performance fuel preasher regulater. After that i removed the stock fuel regulater and had a number 6 jic tiged to the fuel rail.
I'm running a t56 turbo with a inter cooler. After a little triming i got the intercooler to fit between the grill and core suport. To relive boost is a type r bov. (All charge tubes are 2.5 inch mandrell) After the turbo is a removed muffler (been replaced with a y pipe)then into my dule tail pipes. The mass air flow is still suck through but has been relocated to behind the bumper. The turbo has been moved since the pics, Updated pics soon . Tips welcom thanks
I orderd the last of my stuff yesterday. Has any one run the 66mm throttle body i paid danm neer 300 for it and found out latter that it is only 6mm bigger than stock, dose it make a diffrence or not
If I may, I would like to make a suggestion. I'm not trying to "flame" you or anything, but you might want to try to use proper puncuation and capitalization.
It is very hard to read your posts, as they amount to one long run-on sentence. It's just very hard on the eyes. Many people will probably skip right over. You'll get more responses, and help, if it's easier to read.
By the way, it does sound like an interesting project.
sounds like an interesting project, but, I couldnt keep reading half way through the first post.
ok. Thanks i'll work on my typeing. So how do i post pics in the threads?
Here is a pic
Ok i got this pic thing figurd out. I'll start the pics of the install this weekend. I'm getting every thing this wendsday - friday, stay tooned
Holly crap man!!! So many questions,where to start!!!first do you still have the 4.0 and how do you plan on tuning this thing??what axels,gears and what trans do you have? Nice work though!!!
5.13 gearing front and back. I'm running lsd's front and back. i have the 5 speed trans, as far as steering im working on a custom high steer ill try get pics. any imput is greatly appreciated
oh and yes i still have the 4.0 goodies consits of
.66mm throttle body
.accel coil
.tayler wires
.pace setter headers
.a custom remote mounted turbo
the still needs list
.24psi injecters
matched maf
How are you going to tune it?
this is a two year project so far
well when i get it back togeather i figurd i would take it in and get it tooned. although on the outher side iv been talking to jet performance and they are intresed in building a chip
Ok guys I fixed my first post easyer to read
how the intercooler fits
my first atempt at steering. I dont like it high steer conversion next
charge tube frome turbo to intercooler mocked in place
charge tube from intercooler to intake mocked in place
ok bought new camara will post up dated pics this weekend
thanks will get pics soon
Looking at those pics, I'm starting to miss my 91 explorer. Have you noticed any turbo lag since you installed it? I had turbos on my Ford GT40 but took them off and went back to the Supercharger because it had so much turbo lag in it.
