don't have a 97... just 96. The manual says "in steering column, below instrument panel". From the picture and looking at the vehicle, it appears that you have to remove the panel under the column to see it. Again on a 96. Anyways, it is a good chance that your problem lies with the turn / hazard flasher... but it might not be bad... just missing a connection (or two). There are two hots running to it, one all the time and one on ignition. There is one ground (a likely candidate). Two outputs, one for signal, one for hazard. Hopefully your 97 is similar or someone else provides you with more "97ish" info. wire wise (96ish), blk is grnd, r/w is hot all the time (note not w/r), and o/y is ignition hot. Hope it helps a bit
