Digging up an older thread here-this time for my kids 1998 Mountaineer.
My son Matt is in Rolla, Mo for school. His turn signals do not work, emergency flashers do work.
The fuse diagram in owners manual, nor this thread. ( I copied the info in the below thread directly from my 1998 owners manual. which is word for word with my 2000 owners manual concerning the interior fuse panel)
http://www.explorerforum.com/forums/showthread.php?t=180814&highlight=fuse+relay+distribution are correct.
There is a mis print!!!
The above would direct you to fuse 23 --however slot
#23 is unused. The above says 24 is unused, however it does indeed have a fuse there, with wiring.
None of the surrounding fuses are blown. However, fuse 10 (7.5a) is blown and repeatedly blows when replaced.
With fuse 10 blown -all associated fuse 10 circuits still operate. Shift out of park, brake lights, blower etc, all still work.
I believe the turn signal relay to be shorted. He is driving to autozone now for a replacement flaser relay. I will update with answers , hopefully not more questions.
If anyone has a "good" circuit diagram for this area I would sure appreciate it. The haynes diagram I have refers to even more fuses protecting the flash relay. To say I am confused is an understatement.
Thanks!
