pac1976
- June 29, 2004
- Missouri
- 92 XLT 4x4
On my 92 Exploreer the front right turn signal does not work (all other lights work). Switched bulbs, it is not the bulb. The first time I messed around with it it just started working again, must have been a loose wire. Now it's not working and the wire jiggling hasn't worked. My question is:
1. Any suggestions short of replacing the wiring harness?
2. The wire goes under the battery and appears to splice into a bigger wire bundle. Does this WHOLE thing need to be replaced. If so, any idea what the part name or number is?
Thanks for any help!
