- August 26, 2004
- West Virginia
- 1993 2dr
Three years ago, yes three years ago, i removed the abs pump and associated wiring. Well i may have snipped one too many wires. Now that the crawler is about to be used again, i am finding things not working. First the fuel pump had no ground, grounded to frame and that works fine. But the fuel gauge is not working. Also, I had tail lamps but no stop or turn. I am looking through the Ford troubleshooting manual, but it's been a while since I've following wiring schematics. From what I can gather I am looking at a ground issue but wondering if anyone with a little more expertise or knowledge of the first gen wiring could shed some light on where i should look.
all fuses are good, btw. I did check that
thanks in advance!
thanks in advance!
