Blacksheep Josh
Slinky+Escalator=Fun
- July 31, 2006
- Statesboro, GA
- '01 Ford Ranger, RIP 93 X
Installed amp and sub few months ago, worked great.
Originally I just had a power wire from a distribution block near the amp, run to a switch in the front and then to the back. I'm guessing there was to much power going through it because the amp shut itself off. It wasn't until I hooked up the remote wire properly to the rear of the head unit adn replaced the fuse under the hood that it started "working".
Now here's my problem.
I used a quick connector, one of those that you just slide over the wire you need a signal from and close it and it "cuts" into the old wire to give the new wire a signal? Does this make sense?
Anyways, I still have it running through a switch on my dash (so I can turn the system off when cops come close, but now when I turn the switch on, which should turn the amp on, not only will the subwoofer/amp not come on, the speaker output goes as well.
I'm thinking that the power coming through the remote wire isn't enough to signal "turn on" to BOTH amps, and I'm wondering:
Where/what is a safe power source to run the remote wire to? Like can I use a 5amp supply from the fuse box for this that I can just piggy back?
I'm using speaker wire currently from the switch to the amp, should I try a smaller wire or just another power source all together?
