Joe Dirt
- October 4, 2007
- 07 Camry
Ok, for about 6 weeks now, I've been noticing this, and would like to fix it now.
When turning, when I get to close to full turn, the truck seems to slightly bind. My other V8 AWD didn't do this at all. The TC is not at fault. CV's and bearings are all brand new. Same binding was there before replacing them...
When returning wheel to center after the turn, from 1/2 turn to 7/8 turn I get a small vibration in the wheel.
About 3 weeks ago, I had to refill some PS fluid, as it was about 1/2" low in the resevoir. I did turn to full turn, shut off and let system bleed overnight. Problem was not remedied.
Sometimes when driving, I get a vibration when driving straight between say 45 and 70. Sometimes I can hear it too.
2-3 times, I've gotten a whining, pretty loud- when moving from whatever speed to nearly stopped. Once whining, the speed of the truck doesn't much matter. I can stop the truck, shut off for 15 minutes, come back and no noise when I drive it again. The time shut off isn't diagnosis, just after parking it went away.
I have zero discernable play in the U-joint between the front axle and the transfer case, and no evidence of leaking or lubricant breakdown from the joint.
There was a minor leak from the front diff, but that was remedied by replacing the CV's/seal. There was still adequate fluid in the diff.
Tires are all brand new and obviously matching.
Thoughts?
PS pump? Rack going south? Maybe a U-joint? I don't think it's a U-joint or it wouldn't exhibit the turning thing, yes?
Thoughts?
