03Explo20
- January 4, 2013
- Jonestown, Pa.
- 2003 Explorer XLT
Well, I attempted to change out the complete upper control arms on the front today and was unsuccessful! I started on the drivers side and had one helluva time getting the bolts to break loose with all the rust and corrosion. I was able to finally get the 18mm bolt on the steering knuckle loosened but could not get the damn ball joint to pop out of the knuckle no matter what the hell I did! I beat the knuckle with a small sledge, used pry bars, jacked up the suspension to relieve down force, I tried it all and nothing worked!
The two 11/32 bolts in the back, I was able to break one free by hand but not able to remove it all the way and the other took my 350 ft lbs of force lug nut gun to break it free! That also was unable to come all the way off!
I wire brushed the threads, sprayed the nuts, everything, to no avail! I finally just gave the hell up and will have to pay someone to do the work! The friggin Pa. winters certainly did a job on these parts! The ball joints are completely rotted away so I'm kind of stuck in having to have this done for inspection.
I'm really disappointed as the instructions and advice given here really made me think this would be an easier repair job than it was. Thank you to all who replied to my previous threads with help and advice!
