digitaltrucker
- July 5, 2011
- Texas
- 2023 Explorer Limited
My son called said his 2014 Explorer limited was running rough. Went over and removed engine cover and immediately saw where a critter had eaten thru a far left (first) fuel injector wire. V6 Engine
So we quick fixed it by disconnecting the battery, cutting and light solder the wire back together that was eaten thru and then tape. (just a quick fix until we can order a new pigtail.) Quick test drive and the car runs like new. Check engine light is now gone also.
PROBLEM is: The P0204 and P0304 codes will not clear, using my Autel scanner.
QUESTION: Should these clear out? Is it a scanner issue or do we still have an issue?
No I did not scan the vehicle prior to making the repair only afterwards.
