Underdrive Pulley install | Ford Explorer Forums
trucku
Queens, New York and living in Budd Lake, NJ now.
2002 Explorer XLS 4.0 4x4
I finally got around to installing the Underdrive Pulley.
I was planning to do it this summer, but my truck developed a horrid squeal. This occured after I just changed my serpentine belt 3 months ago. Since I have had this truck I have had to change the serpentine belt every year. I knew that something was wrong, but it was not so apparent. I changed my tensioner and idler some time ago when I first experienced the squeal during a winter.
So in the last 2 weeks I changed my serpentine belt. I changed my idler pulley and whole tensioner assembly just in case one was defective. So my truck was quiet for 1 day and then the squeal came back. I ran her without the serpentine and found no noise. I was led into a false discovery when my alternator made some noise. Lucky thing it was still under warranty and I was able to exchange it without incident (Pep Boys). I still had the squeal. I then thought maybe that the water pump pulley was glazed over from the old belt and now is too smooth to allow the new belt to grip. So I took my dremel tool and sanded the pulley and eliminated any shine. Now my squeal got worse. I ran the truck with the AC on also, but I still had this pulsing squeal. Then I finally looked down and saw my Harmonic Balancer wobbling around. I have always seen that my tensioner pulsed back and forth and knew thought that maybe my crank pulley had issues. Seem now it gotten worse enough to wear down the backs of the belts as they slid back and forth on the water pump pulley.
I went out and bought my Harmonic Balancer Puller from Pep Boys.
So my troubles didn't end. I did read here that the 8m bolts that come with the kit is too short. I was unable to find any from the hardware store. I then bought a cam shaft puller kit that had two 8m bolts about 1 inch longer. This proved to be too long and did not allow the puller base to sit firmly onto the crank pulley. To resolve this problem I bought a pack of washers and then added about six to each bolt and that worked fine. Now your tool still has an two issues. One is the bolt is too long and will not fit between the radiator and crank pulley. Lucky thing I bought the cam shaft puller and its bolt was much shorter and fit right into the pullers base. The second issue is that this bolt/screw does not seat into the crack shaft to allow the pulley to be pushed out. I figured this out while using a small mirror and flashlight to gain a viewing advantage into the pulley. I used the installer bolt that came with my ASP Underdrive Pulley. I threaded it in about half an was left then I was able to use the pulley remover. I threaded it in that far to avoid the risk of damaging the thread in the crank. Three times I had to remove the puller and back out the install bolt when it bottomed out on the pulley. The pulley came off smoothly and I felt no binding. I then attempted to remove the seal from the engine with no luck. I did not want to damage it in anyway so I left it in. I cleaned it and around it with a new shop rag. I also transferred the oil slinger from the old pulley to the new one. It just pops off with a little force.
I added RTV sealant to the pulleys keyed slot and then generously oil the outer surface that will contact the seal. I wanted no dry spots or risk of damaging the seal when I put in the new pulley. The new pulley was put in using the installer bolt supplied with the ASP kit. After the bolt was in about half way I took it out and used my original bolt. YES I KNOW....I am not supposed to use it again. Unfortunately I did not order a new one. I put some thread sealer on the bolt and then tightened it down. Another issue I had was not being able to keep the pulley still. So at just over 40# the crank turned a bit. I reinstalled the serpentine belt to gain some friction, but it still turned and my torque wrench clicked at about 45#. I will order a new bolt and install it when it comes it. I will also get a tool to hold the pulley stationary while I tighten it.
I started my car ( no fan installed) and it ran fine. No noise, no tensioner bounce and the pulley is perfectly straight with not a hint of a wobble.
Boy am I tired. Its tough doing this stuff in the street. I actually put one wheel up on the sidewalk so I could slide under the truck. I will put my scanguage to it tomorrow and see how the alternator performs. I know Aldive had to change the alternator pulley to bring it back up to speed. I will order my self a pulley also, so I don't have any issues down the road.
Now lets see if I gain some mpg.
Its late please excuse my crummy grammar.
If you have any questions please post or email me.
Vishant
Test drive:
At idle I noticed my voltage go to 12.7v a few times. During normal driving voltage goes up to 14v. Looks like I need to upgrade the alternator pulley.
Steering feels wobbly and the steering wheel actually bounced left and right a bit when hitting bumps above 30mph. I will also change that pulley to ring it back to speed. I had no cooling issues. My highest temp was 202 farenheit and lowest 198 fareheit.
UDATE:
My shaky steering wheel turned out the be the affects of a loose belt. The correct belt size for the ASP Underdrive Pulley and the other pulleys stock is 83inches. With the new belt everything is running great.Your stock 02 4.0 carries a 85.5 inch belt. the overdrive alternator pulley has been ordered.
E-fan, and now underdrive pulley? Sound's like somebody has been reading up on Al's research;)
Yes I have as all the other threads, but not the reason for my mods!
LOL... ok a little..LOL
The man did his homework and we can only benefit from it.
This summer I am going to do a the whole underside with thin sheet metal and also try to drop her a couple of inches and hope for some mileage gains. I will also extend the air dam down lower.
I have to revamp the e-fan plans. I had issue with it. I might put in some hood vents to lower the under hood pressure when in motion and fan is on. I have been hunting for a hood vent that came on the 80s Chrysler turbo cars.
Hi, you have good information.
I am about to order an under drive pulley from ASP tomorrow morning.
Do you still have your pulley installed? Are you still satisfied with it? Please be sure to let me know, thanks.
Thanks,
The underdrive pulley is still installed. I am very satisfied with it.
I have had no issues with it at all. My voltage at idle is a little low, but I will try to get my alternator overdrive pulley installed.
Too many Planned projects, but just a small percentage tackled so far. Finally have my very own garage now, so I can finally get things rolling. No more "street mechanicing" for me. That was the main reason for why I have gotten so little done...lol
Thanks for the response.
Have you been able to gather any mpg data since your UDP install? I am interested in doing this for MPG gains, not really interested in the hp.
Did you notice a substantial increase in your mpg or was it very nominal?
Thanks!
I did get 1mpg highway more....and I am very happy with that. In city I don't see any difference really.
I have will reinstall my E-fan setup again this summer. I had to put my truck back to stock a while, back so my extended warranty would keep the truck covered. They look for any reason to claim something is not covered.
I believe he ordered his pulley from ASP racing.
I just ordered mine from ASP racing as well this afternoon. I ordered over the phone.
www.aspracing.com
