pj8847
- March 18, 2005
- N.Y.C.
- '95 XLT 4x4 4.0L OHV
Hey all, been a while since I posted, simply because I was kept very busy with doctor appointments, as well as my research into, and repair of my 4R tranny.
Just to recap, My problems originally started with a slight shudder in 3rd and OD under slight acceleration. After a fluid change, shudder was gone, but so was reverse. Found it to be a blown out VB gasket. Changed gasket, fixed reverse, but then developed a 2-3 shift flare. Dropped VB yet again and found new gasket had blown out (cheap thin ford crap) Changed gaskets again, 2-3 shift flare still there, which escalated into the loss of reverse (again) and 3rd gear, decided on new VB.
Ordered new VB from CENTRAL VALVE BODIES, (Donny is the main man there, excellent product). UPS lost the damn thing for over a week, then found it. Installed the new VB (once I got it) and found reverse and 3rd were still dead, but tranny was shifting like it never had before from 1st to 2nd. (VB was definitely doing it's job, and well). Finally narrowed down to blown out direct clutch (due to loss of reverse AND 3rd).
NOW, at present, I finally had the time to scrape up the dough to get my tranny fixed/replaced. Upon removal and disassembly of said tranny, I found that the ENTIRE rear section of the tranny was DESTROYED... (everything from the center support back was mangled, including the case...) The guys at the shop couldn't believe the truck was still moving, and 1st/2nd gear "felt" fine. They said, and I agreed after viewing the carnage that was torn out of the tranny, that I was one lucky **** that i could still drive the truck in the condition it was.
After discussing what to do, I figured the best way to go was a total build, new case, everything replaced, front to back. I had discussed previously with another shop about doing up a 5R, and getting it to work in my truck where a 4R originally resided. Well, it's done. Tranny was built with the case of a 5R, my original 4R bellhousing, new 5R guts/hard parts, new frictions, etc... OSS sensor bore was plugged (the sensor toward the tail of the tranny that is normally used in a vehicle that utilizes the electronic "5th" speed that is available with the use of an appropriately programed ECU) New TC, and my brand new VB was also used, now, I will note this, the VB was built for a 4R, not a 5R, so i am UNSURE if the tranny would have worked the way it should if I had opted to use a 5R VB. (from my research, there is a slight difference in valving, along with some different check-ball placement, and a different EPC on the 5R VB. Any more than that I have yet to discover, and would be speculation based on my limited knowledge of the 5R VB at this point)
Conclusion: The tranny works flawlessly. Shifting is extremely firm, allowing no slippage between gears. TC lockup literally feels like I have a whole additional gear. Downshifting is firm, but smooth. The VB I got from Donny is definitely TOP NOTCH work. All pressures are perfect, All gears engage as soon as the shifter lever is placed into each respective gear with NO delay, even the typically late engaging reverse.
So for any of those out there reading this, who may be experiencing the same symptoms I had, be warned, sure, a VB rebuild may band-aid the problems, and you may get lucky with just doing that and everything turning out fine, but you can bet once you start to get ANY amount of slip in these crap trannies, there is undoubtedly some form of internal damage, whether it be from burned frictions, or failing hard parts, either way, DON'T drive it if these symptoms show up, get it checked and repaired ASAP, because in these crap trannies, a minor failure WILL lead to a major one if you continue to drive it.
P.S. BTW, the whole cost for the build (because of my unique situation, and plentiful contacts/knowledge in the automotive field) came to $1000.
Not bad huh? Better than the $2400+ I was quoted from almost every shop I went to, and much better than the $1500 I was quoted from the first shop I was going to do the build at, AND I was even given 12 month/12,000 mile warranty on ALL parts and installation.
I'd give out the shop name and location, but they asked me not to due to this was a "favor" because of my situation (which has worsened, now they found a "mass" or in layman's terms, a tumor after a new hi-res? MRI of my right leg. Ah well, at least I have my truck back! I'll deal with the knee/leg as it comes... did I say I hate doctors? Oh wait, I said I hated tranny shops!
