urgent HELP!!!! PLEASE SIGNAL LIGHTS PROBLEM | Ford Explorer Forums
chikletz
El Paso, TX
2002 Ford Explorer
My signal lights only blink once or twice sometimes even three times and sometimes they just dont blink I need help finding out the problem if you can help me I will really really appreciate it.
When the signal lights blink slowly it usually indicates a bad ground or a high resistance connection. If both sides are the same the problem could just be a bad flasher unit or a bad connection that is before the turn signal switch. Kind of hard to diagnose with limited info.
I thought so too but i cant find the flasher you think you can help me locate it
You could have a problem with your "Multifunction Switch" where the contacts inside of it need to be cleaned or it needs replacing. The Multifunction Switch is your turn signal, front and rear windshield washer/wiper switch on the left hand side of your steering column. Check the Sticky thread link below for this issue.
http://www.explorerforum.com/forums/showthread.php?t=279556
This is a problem with the realy itself, take it out give it a knock or two, reinstall and test, if still the same issue replace relay.
Good luck
