dae06
- March 25, 2009
- Minnesota
- ranger-1991 and 1995
Where is the vacuum source on a 1997 Ranger? I have defrost only, have read about following the vacuum line and found no problems. When I connect a vacuum pump to the lower vacuum line on the vacuum globe and create a vacuum and my HVAC controls work fine.
The upper vacuum line connects to something on top of the intake manifold that has a steel braided line going down the other side of the engine. Is this the source of the vacuum. If so, what would cause this to not create a vacuum?
My diesel has a vacuum pump, but if I understand correctly, gas engines create thier own vacuum.
