Vehicle speed sensor wire location ? | Ford Explorer Forums
CallOfDuty5
Montreal Quebec Canada
2007 Limited
ware is it
Help !!!!!!!!!!!1
Could anyone tell me where the VSS wire is located on a 2007 explorer limited. I'm installing a headunit with gps and this is required,Thanx in advance!
Not sure on a 2007. You may have to pull it off the CAN Bus. I would recommend going to some place like www.12V.com or www.installer.com and see if they have any answers for you. www.pac-audio.com might have some insight too.
vss wire is at the pcm in a 50 pin plug, pin #1.(purple/orange)
Where is the pcm , could you tell me the location in great detail . I don't know much about factory wiring, thanx in advance!!!
Found the pcm and there are 3 plugs on the pcm,the top plug only has a few wires so i'm guessing plug #1 is at the bottom? I noticed the bottom plug has 4 rows of identical pins meaning it's not a 50 pin???
