Could anyone tell me where the VSS wire is located on a 2007 explorer limited. I'm installing a headunit with gps and this is required,Thanx in advance!
Not sure on a 2007. You may have to pull it off the CAN Bus. I would recommend going to some place like www.12V.com or www.installer.com and see if they have any answers for you. www.pac-audio.com might have some insight too.
Found the pcm and there are 3 plugs on the pcm,the top plug only has a few wires so i'm guessing plug #1 is at the bottom? I noticed the bottom plug has 4 rows of identical pins meaning it's not a 50 pin???
