Open your glove box, press its sides in allowing you to fully pull it out so that it hangs toward the ground.
Using a flashlight, look in the opening and up toward the radio. You'll see a vacuum actuator. Turn the vent knob from Defrost to floor etc. you'll most likely find that the vacuum arm moves in and out but is no longer attached to the door.
