Schitbrick3633
- November 30, 2011
- Farmington, MO
- 2002 Sport Trac
So today I was working on my fog lamps and had to turn the wheel several times to do so to get to the fog lamps. I was parked on pavement and turned the wheel while the key was in accessory position so the truck wasnt running.
Went to take off later on and found that I have a slight tugging or vibration feel when turning the wheel. I also feel it more at low speeds. I should also tell you I just recently put a set of wheel spacers on it and used loctite on the lugs, and havent felt any movement of them when driving.
also, there is plenty of fluid in the PS tank under the hood.
any ideas?? i'm hoping I didnt jack something major up
