OK. here's the deal..... When I accelerate the whole truck shakes badly. Idle is fine and cruising (no throttle applied) at any speed is fine but as soon as I step on the pedal the shakes are back. This problem also seems to be temperature dependent. For example when I leave for work in the morning the outside temp is around 55 or so degrees and the shaking is very bad. When I go home from work the outside temp is around 80 degrees or so and the shaking is still there but not as bad.
I just put a new a4ld tranny in about 10k miles ago. I am wondering if something could have come loose and be causing this problem. So I crawled under the truck last night and did a quick inspection but found nothing significant (I think). The two bottom bolts on the bellhousing (the only bellhousing bolts I could get to without removing the transfer case) were not as tight as they should have been. They were tight, but needed an extra 1/4 turn( not much, right?). So my question is: could the other bellhousing bolts be looser than these which could result in these bad vibrations during acceleration???
I really don't want to take the transfer case out to get to the upper bellhousing bolts, but if I have to, Oh well. Any other ideas or suggestions would be greatly appreciated.
Thanks,
Steve
Thanks,
Steve
