I had a '91 for almost 6 years and must of heard a million different resolutions for the same problem, it's funny but because of the design of these trucks the slightest of balance item can get the whole thing shaking !
Well From my experience and I had alot of shaking with that puppy! I found this (in oder) :
#1 Balance the tires, BUT!! Just don't get them balanced actually go to a small shop and watch the guy do it for ya, I had my tires balanced 5 times and only once were they balanced correctly, when I bent down and watched the tire spinning on the machine and made sure I didn't see any bouncing comming from the tire.
#2 Check your suspension, old shocks loose gas at different rates and one shock can end up being in better/worse shape than another
and finally, what fixed my 65-70mph shake
#3 a new set (all 4 tires) of Michelin XC-4 from Sears that were balanced 3 times before I let them put them on the truck (BALANCE BALANCE BALANCE)
The truck was like glass from 0-100mph (oh yeah and i had pretty new shocks on it too)
Don't forget !! Rotate those tires often and BALANCE them every time you rotate and you will stay in "GLASS Mode" while driving 65/70mph!
Because if you don't the vibrations will return! !
This is only my story on vibration, like I said there are 100 diferent stories!
Good Luck
ToneDog
ps check out this site Dead Link Removed
