XCAMP
- January 21, 2009
- 2005, XLT
Hey guys, really need some help here because my wallet is draining at the local shop. Here's the deal...
I purchased new tires a few months ago, got a balance and alignment. The truck was smooth as glass on the highway and everywhere else. All of a sudden about a month ago, I was cruising down the highway at 65 and I got this nasty shake... like if you had a cup of water in the cup holder, it would be shaking and almost spilling out. Drop the speed down below 60 or go above 70 and it goes away.
So I take it in and get a balance, and it's still there. Then we check the alignment and rebalance, with everything in spec, the shake is unchanged.
Next, they tell me that my front axle is bent and the u joints are bad. So I pay $1K for that fix, including front dif fluid, pinion seal, etc. The problem was still there and even better, I had a major droning noise at those speeds, so they tell me it's the rear axle and they replace that.
So I have new axles, front and rear, new pinion seal up front, new u joints, and I still have the problem.
Before I took the truck in to them, I read my service manual and it said that if you experience vibration, to test drive it and shift to another gear and see if it goes away... if it doesn't, it says that it's not the drivetrain. I told this to the mechanic when I took it in but he insisted it's the drivetrain.
Any advice would be more than appreciated since it's back in the shop now.
