victoria dlk
- May 23, 2009
- Perth Western Australia
- 98 4ltr ohv
Many thanks for your site over the years. With it's help I have done the following modifications to our 98 Explorer;
2 Oil coolers in front of other rads.,
Disconnected the oil pipes from the water rad. and connected up with an oil hose;
Plugged water rad. holes;
Fitted hydraulic oil filter (lower micron) not engine oil filter on return pipe to gear box.
IN the gear box....
fitted new pressure control valve;
fitted new pressure relief valve;
Block open oil temp. thermo with 1/4 " nut;
fitted bonded gasket plate;
fitted 2 cast ali blocks (firm fit) in long oil channel to stop movement of sides breaking gaskets;
Reason for above mods , West.Oz is hot climate like south USA. also we tow heavy horse trailer long distances.
Gearbox has now done 250,000 Km without trouble. Any comments or suggestions would be very welcome.
IN the gear box....
