VSS problem ? | Ford Explorer Forums
VSS problem ?
Matie
Abu-Dhabi UAE
Explorer 2003 & XLT 96
Hello There,
I am facing excetly the same problem as Jack & Russel faces in the past around 2005, Speedo meter needle is dead, Engine Service yellow light is lit, O/D is flashing, after reading this threat I have checked VSS ohms value its 229.7 ohms. Looks ok, do I still need to change & check ?? I also tried shuffling wires & connector, but still the problem persist any further advise will help!!
Regards
Matie
