prayforsurf0
- April 7, 2015
- Montauk NY
- 1998 Ford Explorer XLT
My speedometer stopped working and I started having some weird transmission bumping. Got P0500 code (VSS). After buying the wrong VSS (transfer case mounted VSS) I went back and got the correct one that is mounted on the rear differential. I replaced the old sensor with the new and it still doesn't work.
I did notice that the new VSS sensor looks a little different than the old one. The old one has a smooth round cylinder that goes into the differential, the new one does not have a smooth cylinder, rather its more hexagonal shaped with concave sides. I did a search for the same part online and from the pictures it looks like all the replacement parts have those concave sides on the cylinder that goes into the differential.
I also noticed the new cylinder does not spin by hand, the old one does. Shouldnt I be able to spin the sensor by hand ?
Is it possible pieces of the old sensor broke off into the differential ?
